Thunderbird keeps rejecting password to set up email account
Old desktop on xp died but hard drive ok. Settng up another pc with xp with Thunderbird account for 5 email addresses. 4 set up o.k but last 1 password keeps getting rejected. How do I get over this pls.
Also how can I migrate contacts and emails form old hard drive in a caddy?
എല്ലാ മറുപടികളും (1)
Contact the email provider and check about the required server settings. With the settings you obtained try manual setup. https://support.mozilla.org/kb/manual-account-configuration
Who is the email provider anyway?
The easiest way would have been to copy over the entire profile from the old disc. Since you do seem to be beyond that point, see http://kb.mozillazine.org/Transferring_data_to_a_new_profile_-_Thunderbird
